Results 1 to 8 of 8
Thread: AE101 Fuel Line Size Help
    Luke
    Default AE101 Fuel Line Size Help
    Hey people,
    I'm doing a 20V ST conversion into my MK1 Cortina and wondering what sizw fuel lines I need to be running
    The lines that go to the FPR are 6mm?
    I have a surge tank setup and want to run the correct lines
    Can someone point me in the right way for lines to go under the car and the size's
    Moderator Sam-Q's Avatar
    Endeavour Hills
    cant use the original steel lines under the car? AE's use 6mm for the feed and 4mm return
    Luke
    I don't have any lines at all, starting from scratch. Does it need to be a EFI hose?
    Endeavour Hills
    well normally under the car you use metal lines and then join them to the tank ank engine via efi rated rubber hoses. There are places around that sell the metal lines or can do the job for you
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    could just run rubber the whole way thats what im doing(long story short i pulled my hard lines out) yes you need 5/16 EFI fuel hose
    Aaron
    My 20v halfcut had 8mm inlet with 6mm return lines
    Glenn ke_70's Avatar
    Clay
    Barossa!
    run hard lines because you'll get rocks and shit flick up and rupture them. +its cheaper to get hard lines.
    i was going to do the same thing with my car.
    Michael
    Crimebrook 2749
    i retract my earlier statement been alying under my slut heap of shit for like an hour looking for places to run rubber lines, im going to make hard lines(70 bucks in hose wasted ffs)
  1. NSW WTD ae86 gt fuel tank, pump and fuel line supply
    By smash in forum Cars or Parts Wanted
    Last Post: 2nd February 2012, 09:09 PM
  2. Fuel Line Help!
    By tc-rolla in forum Technical - Questions
    Last Post: 14th July 2010, 03:04 PM
  3. JDM Fuel line size
    By luke86 in forum Technical - Questions
    Last Post: 29th January 2010, 02:53 PM
  4. Fuel Tank Size and Fuel Economy
    By focus_7 in forum Technical - Questions
    Last Post: 14th September 2008, 12:12 AM
  5. t18 fuel line and return fuel line
    By fozz in forum Cars or Parts Wanted
    Last Post: 23rd December 2007, 04:55 PM
