Oxy sensor??
hi i l finally got my 4age bigport tvis running in my ae71, it runs not bad but every now and then it splatters down low and feels like its choking and idles alittle high, i have the cold start vavle blocked off(big hole in throttle body), check for vacum leaks none, timing is fine, if any one has any ideas what else to check it will be appreciated, and also does any one no of any workshops with experience with these engines in melbourne near the northern suburbs?????????
Oxy sensor??
John 1:12
i first thought that but it's not all the time
Under load or free-revving?
First port of call would be a new set of plugs.
take out the plugs and attack them with a wire brush, see if that helps. re gap them too.
other option is your injectors may need a clean, but try the plugs first.
- Blaise Pascal
its under load i'll go buy plugs tomorrow, i'll let yous no.
thanks
forgot to mention it is when the car warms up
changed plugs today and still no good, any1 i'm out of ideas
can you get someone to rev it while you pull leads off, to try and isolate what cylinder/s it is
