I have a couple of questions regarding the components and set-up of a fuel system to supply an ST20v in a KE70.
[1] Can I run the standard KE70 metal pickup lines (the metal pipes that are inside the tank which the pump is attatched to) and just attatch a walbro (supra or something) or bosch (VL etc) pump to it?
Obviously I will have a surge tank and a secondary pump. The reason I ask this question is that I am worried that these standard KE70 fuel pickup pipes are too small in internal diameter to handle the extra flow of an aftermarket efi pump.
[2] Which pumps, or pickup and pump combo would you recommend for this application? Pretty much I would like to know what to purchase, I know its gonna be two pumps and a surge tank. What I am unsure of is whether to go in tank or in line with the choice of primary pump.
Any help would be great. Cheers
