out of curiousity do you happen to have a dyno sheet?
also location.
Motor built ready to go - all new parts
Balancer - TCI type
Head - ST205 Carlos Sainz rally homologated, ported & polished with isky dual springs and spring cups, ARP Headstud kit
Cams - Computer generated custom.245dur @ .050", .410" lift
Cam gears - Custom Adjustable TRD
Head Gasket - Competition 4340 sealing rings & composite
Pistons - Custom JE, Zero gap Total Seal Gapless Ring set with ductile iron top rings, C/Moly gudgeon pins, HPC coated pistons
Conrods - Custom Pauter with ARP2000 bolts
Oil Pump - Modified genuine hi-volume
New Genuine Toyota belt , seals and tensioners
Valves - Multi-angle, HPC coated valves
Crankshaft - Crack tested, balanced, ground, polished & nitrided
Intake manifold - Custom intake manifold and plenum - minor work required
$8000.00 ono
Motor assembled by Ashford Racing by Mark Ashford at
Twin Turbocharged 2JZ EE/AA Competition Altered "in the build"
ANDRA Index 7.25sec
http://www.undapresharacing.com
also location.
Sorry motor hasnt been dyno'd. I was going to put a GTK1000 Turbonetics turbo on the side of it and make around 900HP but I have decided to go with a 2JZ instead.The motor is located in Brisbane.
ANDRA Index 7.25sec
This motor will accept any turbo size combo you can think of for your car...
ANDRA Index 7.25sec
Need motor to go... contact me with your offer
ANDRA Index 7.25sec
You will not be disappointment with this quality motor...
ANDRA Index 7.25sec
Price reduction down to $7000.00..
ANDRA Index 7.25sec
