Results 1 to 3 of 3
Thread: 4age wont run, replaced throttle body.
    Junior Member luke's Avatar
    Luke
    Geelong
    Default 4age wont run, replaced throttle body.
    Car - ae86
    motor - 4age
    use - daily
    problem - Engine starts when key is in the "start" position, but turns off strait away when it springs back to the "on" position.
    occurs/started when - Hey all, I've just replaced the throttle body on my ae86 with one i grabbed off an ae92 from the wreckers today (Replaced because old throttle bodys return spring on the shaft was screwed). Engine starts and will run for as long as you hold the key in the "start" position, but as soon as it springs back to the "on" position, it dies staright away. Any ideas??
    Veteran blake.'s Avatar
    Jun 2009
    Blake
    Penrith
    so you grabed a throttle body off a ae92, i assume it was a small port 4age.
    is your engine a smallport 4age?
    could be the tps sensor is fucked/ needs adjusting.
    bursting ovaries since 92'
    Luke
    Geelong
    Found the problem, immobiliser switch is screwed. Thanks for the reply anyway blake.
  1. 4age, fires speratically but wont run.......Help please
    By RacerMelb in forum Technical - Questions
    Last Post: 29th July 2012, 09:17 PM
  2. 4age bt wont rev past 6500rpm at full throttle
    By matho in forum Technical - Questions
    Last Post: 22nd July 2012, 09:38 PM
  3. 4age throttle body
    By jdmke70kid in forum Cars or Parts Wanted
    Last Post: 15th September 2010, 09:06 PM
  4. 4age throttle body
    By Eddy in forum Car Parts For Sale
    Last Post: 30th July 2007, 04:43 AM
  5. 4age wont run on other ecu's
    By mikes86 in forum Technical - Questions
    Last Post: 7th July 2005, 10:23 AM
