Are u checking the level of the oil once the relocating lines hav been filled up. If u hav long lines and they fill up could drop the level to low.
hey guys heres my prob i have an 86 with a 4a 100kw in it i have blown 2 bottom ends in 2 completely diff motors in 2 weeks the only thing that i have changed on the oil system is a aftermaket oil filter relocation kit and a diff oil cooler and braided lines could this be the problem??
yes the levels are all fine and the car seams to run fine for a few days the i heard a slight knock that got massively worse in minutes
have you got a oil pressure gauge????, sure you have the kit mounted right and everything??
make sure your getting oil pressure then, sounds like bottom end isnt getting oil
no gauge atm but yes all the kit is done properly could it be a coinsidence that the same thing happened to 2 diff motors?
i would be getting an oil pressure guage and seeing if your getting good oil pressure, and i would be checking the kit, what brand etc is it
i brought everything from motorsport connections payed good coin for it and its all good gear couple of my mates think that the extra kit shit and cooler is to much for the oil pump?
not that im 100% sure on this, but i havent read anyone on here saying anything about oil pumps struggling, after running cooler kits, but like i said get a oil gauge on it, even borrow or buy a oil pressure gauge(like a kit for testing not an incar gauge)
wat press should they be running??
What size lines? How is it plumbed up?
You haven't done something dumb like fed the oil backwards through the filter have you?
I would rebuild motor no.1 and rather than getting an unknown km shitty condition motor again, then see if it blows up again after checking oil pressures.
