Results 1 to 10 of 12
Thread: sr20 piston not pumping?
    Junior Member Kris's Avatar
    Jul 2010
    Kurt
    Default sr20 piston not pumping?
    motor -
    sr20
    problem -
    Piston not pump? just one of them i think
    occurs/started when -
    all the time.
    personal situation (if applicable)-
    Hey guys, I picked up a s13 silvia with an sr20 to go into my rolla. The Engine did work before my mate crashed the rear end and its been sitting in front yard uncovered for about a year now. The engine is hard to get started and once it does it stalls unless i floor it and it will slowly build revs but not much. Its like one of the pistons arnt pumping and the rest of them have to push it. Ive checked all the spark plugs and the dizzy. No idea, can anyone please help.
    Fucked injector.
    Dirty AFM.
    Fucked fuel pump.
    Bad fuel.
    Fucked coilpack (if turbo).
    Fucked ingnitor (if turbo).
    Theres some things to start checking.
    Jul 2010
    Kurt
    Problem found, retested the spark plugs ( in the dark this time, so i could see them ) it was actually one piston pushing the other 3 along. then tested all the plugs, they all worked so started swapped the lines around to test them and they all worked, so id say the dizzy is fucked. thanks anyway.
    Jul 2010
    Kurt
    Sorry guys, i replaced the distributor and all sparkers are working. The cables are in the right places. the engine turns over but it wont start. It makes poping noises as the engine turns but no roar. I am researching at the moment, but just a bit of extra help would be REALLY handy. I need to pull the engine out tomorrow and get rid of the rest of the car tomorrow.
    Aaron
    sounds like timing is out
    Veteran Pidgey's Avatar
    Sep 2009
    Ry
    Sunshine Coast
    check that the distributor is actually in correctly, it could be out a tooth or two.
    [SIGPIC][/SIGPIC]
    Quote Originally Posted by Jacobxxx View Post
    I will legitimately drive nude...
    Veteran Rice86's Avatar
    Richard
    Liverpool
    check timing and if that isnt it, get a new engine i say
    EDIT
    what else have you done? serviced the car with oil change etc..?
    dose
    Veteran anastasios's Avatar
    Taz
    Earlwood
    sounds like timing to me too
    Jul 2010
    Kurt
    Alot of thanks guys, ill get onto the timing. Havnt really serviced or changed the oil. I dont think its worth the effort until I know for sure the engine runs.
    Site Supporter Javal's Avatar
    Josho
    Sounds like you have absolutely no idea what you're doing.
    First off -
    Check ignition timing, especially actual timing of the distributor.
    Check cam timing, although if the motor was fine before, and you haven't touched it, there's no reason why this should be out.
    Real question is, what have you fucked with between it coming out of your mates car and it going in to yours?
  1. AE71 GUARD PUMPING
    By daveAE71 in forum Technical - Questions
    Last Post: 2nd November 2012, 03:19 PM
  2. Replies: 0
    Last Post: 13th August 2010, 12:32 AM
  3. Setup ae86 with sr20 or s13 with sr20
    By MR 86 in forum Technical - Questions
    Last Post: 5th July 2010, 11:56 AM
  4. PISTON
    By Mr Fujiwara in forum Cars or Parts Wanted
    Last Post: 1st October 2007, 10:07 PM
  5. Piston Rings
    By wideslider in forum Technical - Questions
    Last Post: 20th March 2006, 08:22 AM
