Results 1 to 10 of 17
Thread: Car not running smoothly after installing surge tank
    The Ghetto
    Default Car not running smoothly after installing surge tank
    hey guys ive just recently fitted a surge tank setup in my car. However now my engine is not getting enough fuel as the car is not running smoothly and is misfiring. Ive double checked all the hoseing and everything looks to be in the right spot. Im thinking the fuel pump is not pumping enough fuel?? Also when i switch the car to ACC the fuel pump doesnt run, only until i completely turn the car on then it decides to pump fuel.
    If anybody can help me out it would be greatly appreciated. Thanks
    The Ghetto
    Also its 4age engine running a possibly borsch 070 or 044
    Veteran Skylar's Avatar
    Ken
    What lift pump?
    Twin external pumps right?
    Return to main tank or surge tank?
    Normal for fuel pump to run on ON pos only. why do you need fuel to listen to stereo/light a cig?
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    how do u have the fuel pump hooked up SHOULD be triggered off the ecu!
    what lift pump?
    fuel comes out the tank via the lift pump -> the surge tank -> the main feed pump -> the fuel rail -> to the surge tank -> to the fuel tank!
    ive seen lift pump wired up backwards so it works backward
    thats all i can think of for now
    AE86 THE BEST
    The Ghetto
    hi eddie ive got a facet type lift pump and the fuel is connected up just as u mentioned. I dont really know much about electronics my mate helped me hook her up but the fuel pump is connected via the same connection as the lift pump.
    Skylar what i meant was that when u turn the key u should normally here the fuel pump work before the engine starts
    Ken
    Big ports don't prime, the fuel pump will only run when the CAS is spinning or the key is in the start position.
    I take it it ran fine before installation of surge tank?
    Mar 2010
    what your reffering to is that the fuel pump doesnt prime before you turn on the car
    The Ghetto
    yeah it ran alright alot better than what it does now. Yeah thats what i meant sam.
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    may sound stupid, but you sure you didnt get the return line mixed up with the main line to the engine??
    will still feed engine fuel but no where near enough
    The Ghetto
    ill triple check tmr lolwat. Im pretty sure everything is correct
  1. Replies: 10
    Last Post: 30th May 2012, 07:46 PM
  2. under car surge tank
    By EVOSTi in forum Technical - Questions
    Last Post: 11th September 2008, 02:44 PM
  3. for sale , surge tank, aus fuel tank, hood linning + more
    By hillclimb86 in forum Car Parts For Sale
    Last Post: 20th June 2007, 12:20 PM
