Results 1 to 10 of 12
Thread: trans fluid....amounts
    Ade
    SYD, Inner west
    Default trans fluid....amounts
    Just wondering how many litres of trans fluid is needed for the gearbox, and how many litres is needed for the diff?
    had a couple leaks that have been repaired....can't remember how much came out of each! (only using one oil pan)
    AE86....robbing me! check the build.
    http://www.ae86drivingclub.com.au/fo...read.php?t=445
    Veteran johl's Avatar
    Johl
    1.7L gearbox and around 1.3L for t series diff. diff will be easy because you just fill it through the back and when it overflows you know you have enough. i'v always filled my gearbox through the shifter and there is no way of knowing if you have enough oil in there so i measure it before i pour. or if you can actually undo the overflow on the side of the gearbox you can just fill it till it overflows from there
    Veteran blake.'s Avatar
    Jun 2009
    Blake
    Penrith
    I think we should have an article on oil capacity for toyotas
    As this is not the first tim it was asked, I remember asking this exact question a while ago
    bursting ovaries since 92'
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    dont only use a certain amount, fill it till its full, for G box, pull out "filler" plug if the cars on the ground, poor oil through shifter hole until it starts to come out of the filler plug
    Diff, fill it though the filler plug until oil comes out
    i dont see the point of having amount of oil its "meant" to have just fill it till its full
    Ade
    SYD, Inner west
    Cheers mate, i assumed that. but i didn't have a big enough socket to undo the fill bolts.
    Michael
    Crimebrook 2749
    use a shifter just be careful, in that case the speedo is pretty inline with the filler plug from memory pull that out and wait for the oil to come out then jam it back in
    Jun 2009
    Blake
    Penrith
    I rounded off my level plug with a Mexican socket wrench, that's why I needed the capacitys
    Michael
    Crimebrook 2749
    drive it round ill get it out
    and do what i said above
    Veteran timbo's Avatar
    Tim?
    Wild West
    i cracked mine with a half drive socket on a small breaker bar with a 1.5m broom handle attached and 10cm of leverage. win.
    Michael
    Crimebrook 2749
    people fuck them when they put spanners on the and hit the spanner with there hand and it slips and they go DER let do it again
    timbo is smart
  1. WTB: 4ac trans
    By hillzy in forum Cars or Parts Wanted
    Last Post: 13th May 2012, 07:33 PM
  2. 4a-c trans onto 3a-u
    Last Post: 14th December 2009, 09:04 PM
  3. So much amounts of WIN
    By dave2221 in forum Offtopic Discussions
    Last Post: 28th April 2009, 05:09 PM
  4. Changing Trans Oil....
    By fat exa in forum Technical - Articles
    Last Post: 9th August 2006, 09:09 PM
  5. Oil Amounts
    By vbman in forum Technical - Questions
    Last Post: 24th November 2005, 08:26 PM
