are you after a quick shift or short shift
how to modiyfy the existing w58 shifter stalk?
can some one plaese fill me in on how i can make a short shifter for my w58 before i install it?
can i remove the shifter stalk from the linkage and lathe,die&tap a new one or would i have to cut it?? (wich i dont want)
Karter, Apprentice; shoe string budjet
CORONA' good to drink good to drive, but Don't whatever you do; mix them togeather
Curent project: 3SFE powered W58 ST141 Corona
This will not give you a quick throw just a shorter stick
yeah short; 1; the smalest diffrence in speed 2; so i can use the sterio properly 3; it looks and feals better to drive.
You'd have to machine up a spacer for the shifter housing, and cut/weld or somehow extend the small 'ball' on the end of the shifter to reach the shift socket. If you wanted to do this yourself.
Or buy an already made W58 short shifter.
Andrew
