Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
Thread: strut braces, cluster, modified oil sump, T series, Rose Jointed arms, HKS oil/water
    Bert
    Default ae86 cluster, modified oil sump, T series, Rose Jointed arms, HKS oil/water
    PRICES REVISED!
    hey guys
    need to clear out some stuff and get the funds back up to continue with my car build.
    im located in Melbourne S.E. suburbs
    modifed 4age sump for extra oil capacity: looks like it would hold maybe an extra 500mL to 1000mL of oil, havent run it myself nor did i make it. it has a oil drain banjo for either oil cooler, welds look very good and its just got a bit of surface rust, comes with some old pickup.
    $80
    Now $50
    ae86 cluster with 285xxx Km, was all working well when it came out of the car.
    $30
    Now $20
    HKS temp guage: can be used for Oil or Water, white face with green backlighting. picture shows its working in a mug of boiling water. it is a cannulated type (mechanical) comes with a plug for power
    $120
    Now $90
    T series from a T18 corolla, drum type, has a locker in it wasnt noisey when i ran it, handbrake locked very well.
    $600
    now $450
    Rose jointed trailing arms, as you can see they are still attached to the diff, they are in good condition but as some of you know rose joints can deteriorate over time, especially with a locker, which is what has happened. one looks like it was rubbing on something also im sure what, may have been the old exhaust.
    $160
    now $150 COME ON these are cheap!
    im open to offers and i honestly dont even know what half this stuff is worth anymore.
    my number is 0431 475 306 call or SMS after hours, SMS prefered during work/school hours or reply in post or PM
    cheers
    Veteran johl's Avatar
    Johl
    they look like the trailing arms gilly had made up. if they are you are selling them ridiculously cheap
    Senior Member Stain's Avatar
    Derek
    Far North
    I'm sorry... but... WHAT?!?!?!
    Bert
    Originally Posted by Mr Fujiwara
    rear: weld in type, average condition the picture will explain the rest
    $20
    I don't understand?
    May 2010
    Glen waverly
    That brace was not supposed to be welded in, you are supposed to drill holes on each side and bolt it down, I believe that's what he is saying
    I'll give you $10 for the brace if you really don't want it ^_^
    Bert
    oh yehhhh its been cut out of the car in that pic too, i wasnt the one put it in my old car, but the car was written off so i cut it out because i figured someone might want it, if you want it come get it. i just put it up mainly because i was going to chuck it anyway, and i figured it would need a while grinding it for the buyer so i made it cheap.
    Veteran timbo's Avatar
    Tim?
    Wild West
    just grind off the welds and sell it for more and also avoid comments on the epic fail that it is!
    Site Supporter matt99's Avatar
    Because everyone drills there bolt holes to exactly the bolt daimeter and we never get flex from bolts do we.
    Weld, structural rigidity.
    Tim?
    Wild West
    my issue isn't with welding the strut to the shell it is with cutting the wheel arch to remove it!
    Bert
    this is why i didnt bother cutting the brace out neatly just so you know
  1. Modified Sump / Oil Pan
    By Stain in forum Technical - Questions
    Last Post: 14th July 2011, 07:40 PM
  2. Rose Jointed Adjustable Trailing Arms *E7*
    By Mr Fujiwara in forum Car Parts For Sale
    Last Post: 29th April 2011, 03:16 PM
  3. Rose jointed rear trailing arms/JDM cluster
    By Zenki in forum Car Parts For Sale
    Last Post: 12th June 2009, 08:28 PM
  4. Replies: 13
    Last Post: 18th November 2007, 08:22 PM
