Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
Thread: Running rich?
  1. #11
    Hamish
    eden hills
    plugs are spotless and dash pot is fine. dunno what injectors im running.
  2. #12
    Senior Member Casey-G's Avatar
    Casey
    What color are they? (injectors)
    Are you certain the timing is right?
    another thing i'd like to know is if its a map sensor or afm type load? is it a bigport or a smallport in other words (assuming its a 16V)
    You really need to give us a bit more information if you want even the slightest bit of help.. its not exactly easy to diagnose a problem online with sfa info
  3. #13
    Mt Macedon
    If you're running a stock ECU then pull error codes from it. They may point you in the right direction.
    Also more investiagtion and information will help with diagnosis, both for you and anyone trying to help on the internet.
  4. #14
    Forum Sponsor TODA AU's Avatar
    Feb 2011
    Adrian
    Thornleigh
    It could be a dodge O2 sensor, but it also sounds like the tps is out causing an issue with the overun fuel cut.
    Check the voltage, adjust as required then re-do the ignition timing.
  1. 4age running rich
    By kk86 in forum Technical - Questions
    Last Post: 20th March 2012, 02:49 PM
  2. 4age running really rich, not sure what to do!
    By Sprinter Freak in forum Technical - Questions
    Last Post: 12th February 2012, 06:58 PM
  3. Running rich
    By RolandGTV85 in forum Technical - Questions
    Last Post: 24th April 2009, 11:10 AM
  4. Running Rich
    By grape_moosha in forum Technical - Questions
    Last Post: 29th January 2007, 11:28 AM
  5. running rich
    By Maxhag in forum Technical - Questions
    Last Post: 1st June 2006, 06:52 PM
