do you want to take the whole dff out or just the centre? borgy or t series?
hey guys im sure this question has been asked before, but i have tryed the search bar and have had no luck.
last nite took my corolla out for a drive and unforunatly broke my locked diff (think i snapped the weld inside)
so just wondering if anyone could help me with a little information on how to take the diff out,
is it a hard procces?
are there any special tools needed?
any help will be greatly apprceiated
thats a good point,
what i basicaly want to do is take the diff in the car now out, and a put a new diff in? that make sense? and its just a stranded diff
Wat ever u can see is connected to the diff. Undo. Put a jack under the middle so it doesn't fall on u
to save having to disconenct brake lines, undo the backing plates on the drums and slide the axles out and unclip the solid brake line that run along the diff housing and pull the rest of the diff out, leaving the brake assembly behind
hey guys, thanks for all your help, today i took out the axels and gear set and have relized that my gear set is completely fucked!
what gear sets go stright into a borg warner diff houseing?
if i get a t series what do i have to change? handbrake cable? do the swat bar mounts and all that shit the same?
bolt in, will need a tailshaft
Hand break cables from it will not work tho. Im having this issue with mine, I'm gunna fix it the same way as pen15 did, with a hydro handbrake.
Just get the tail shaft to and everything will bolt in, assuming you bought a t series from a sprinter.
