Results 1 to 6 of 6
Thread: T50- won't engage in 5th gear and reverse, any ideas?
    Senior Member 4.5AG's Avatar
    Vener
    NT
    Lyons
    Default T50- won't engage in 5th gear and reverse, any ideas?
    I lost 5th and reverse gear last night during racing. Is it possible that both synch roes are stuffed?
    Any ideas to what would hav caused it.
    Cheer,
    Vener
    Senior Member worked's Avatar
    ed
    tas
    wynyard
    i've heard some people have had this problem and it was a broken selector fork apparently??
    they aren't too hard to split apart and have a look at
    NEAR MISS
    Veteran Skylar's Avatar
    Ken
    I'd say broken fork too.
    Easy to crack T-50's open, took me forever to get the tail housing in the right spot to get past the end of the shift rods though.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    selector fork sounds right, reverse gears don't have synchro's
    Veteran Andy San's Avatar
    Andy
    Adelaide Hills
    Does the gearstick go into the gate? or does it not move into gear at all.
    If you can still move the gearstick into where it is supposed to go (but there is no drive), then you've probably lost a roll pin holding the selector fork, if not then it's probably broken a fork like the others have said.
    If it has dropped a pin, you can lockwire them into place so they don't fall out again in the future
    Andy
    Vener
    NT
    Lyons
    I pulled the gearbox apart and the fork is ok. The 5th gear sleeve does not slide thru the 5th gear hub. I think the a spring has been dislodged and the key is stopping the sleeve to go engage. I need to press the bearings and synchros for closer inspection..Click image for larger version.
  1. Replies: 21
    Last Post: 11th November 2012, 10:02 PM
  2. T50 doesn't always engage in 1st or 2nd
    By Suter in forum Technical - Questions
    Last Post: 14th January 2012, 04:26 PM
  3. 5th/reverse gear clutch hub or broken gearbox
    By Group A in forum Cars or Parts Wanted
    Last Post: 17th June 2011, 11:37 PM
  4. W58 5th gear weak?
    By Grant #2 in forum Technical - Questions
    Last Post: 9th March 2010, 08:52 PM
  5. Reverse Gear playing up - What Gearbox Oil T50?
    By li21 in forum Technical - Questions
    Last Post: 3rd April 2008, 03:44 PM
