Results 1 to 8 of 8
Thread: the one.
    Senior Member Hachi_Tom's Avatar
    Mar 2010
    Tom
    Ashmore
    Default the one.
    hey all after a friend pointed out that i dont have a build thread on here realised i should post one up haha.
    my car is nothing special, its an 1984 sprinter.
    Mods:
    16v 4a-ge
    rb20 alloy rad with falcon thermos
    ae71 auto diff atm (snapped an s series axle), looking for a t series.
    Standard manifold, straight through 2.5" to twin 2.5" kickups i made.
    Vl external fuel pump
    Coilovers using corona struts with 10kg JIC springs (looking for 9kilo ones if anyone wants to swap.)
    Corona brakes up front.
    Custom made lockspacer
    rear has 6 kilo springs, bigger sway bar, rear strut brace that goes inbetween rear seat latches
    Full Vertex kit
    Has 14x7 -5 Work equips on the front
    rear is 14x8 -12 ssr mesh.
    acquiring some hurricanes with yokohama c drives off a mate soon.
    Plans:
    extractors,
    longer LCA's
    camber tops
    new waterpump
    TRD clutch
    T series
    oil cooler
    TRD blues short stroke for the rear,
    bigger front brakes (these are solid disks i want vented as brake fade sucks)
    Ill make some knuckles, new rosejointed tie rods, adjustable panhard rod, all at work, working at a small engineering shop that has many CNC machines is win!
    attend many more drift days.
    Senior Member Drift_Donkey's Avatar
    Byron
    haha. I knew you didnt have a thread up.
    Driving back last night was fun. So loud
    Quote Originally Posted by marvis View Post
    I also like sportmaxx and incorrectly placed/applied hangrings.
    Mar 2010
    Tom
    Ashmore
    ROFL i dont know how mine is louder than yours when yours had half an exhaust
    and i couldnt find my old one?
    maybe i left it un-updated for so long it got deleted when they updated the site?
    Jul 2009
    Daniel
    Morisset
    nice 86 man, looks like it slides well.
    you mentioned you wanted to do a brake upgrade... you already have the perfect struts for it ...
    the hilux upgrade is the way to go for you .
    hit up a wreckers and look for the even piston hilux calipers, they are also found on 75& 80 series land cruisers. then buy some Peugeot 604 vented rotors and have them machined down in dynamiter from a 272mm to a 266mm then drill out the holes that bolt it to the hub my 1.5mm and they bolt straight on. it is a mad upgrade and should only set you back about $350 but it is well worth it.
    Veteran bigm's Avatar
    Gold Coast
    cute haching
    get some front camber!
    Mar 2010
    Tom
    Ashmore
    Oh yeah, thanks faceplant! will look into it! will the stock brake master be enough to handle the 4 pots?
    and i soon will stopel, soon will.
    Senior Member PHAT86's Avatar
    Allan
    Brahma Lodge
    Looks tuff
    Byron
    Lock your diff. Keen for tandems.
