hey guys
found a t18 drum to drum diff set up, with a locked diff but for a lil extra i can get a 2 way gear set for it.
so just wanted to know will this diff bolt stright into my ke70, 1983 model running a t50 gearbox, will the axels out of my diff fit in the t18 diff or will i need the t18 axels? are the mounting points for everything the same?
Seriously?
Drum to drum means it already has axles in it, as in it's 100% complete differential. xE7x axles will not fit the T-series housing or center. You will need axles from a TE72 (T-18) or zenki AE86 T series should you need to replace them.
All other mounting is the same, as per the S and T series diff info thread, which you also posted in asking a similar question.
Your question about which tailshaft to use has been answered in the other S and T series info thread.
Search and use the template next time.
thankx for the info mate, really appreciate it cheers![]()
