Hey guys, I'm about to start cutting my struts to convert them to coilovers. but I've got some questions before i start butchering things!
I've got celica st185 agx shocks that are going to be used in my ae86 struts.
Because the body length of the celica shock is 332mm and the standard ae86 shocks body length is 402mm, a difference of 70mm. If I cut 40 mm off the casing Il need to place a 30mm spacer in the bottom of the strut? Is that right?
What can be used to make a spacer?
Also where abouts do I weld the coilover sleeve?
I have searched and in most of the threads I've read there are people who have used the spacer ontop of the shock and others put the spacer underneath. Why do people do them ontop or beneath?
