Results 1 to 8 of 8
Thread: Brake compatibility????
    Senior Member Deeken's Avatar
    Jan 2011
    Deeken
    Port Macquarie
    Question Brake compatibility????
    Hey guys, got some ae86 coilovers, came with the stub axle, and found myself some hubs, wondering if there are any compatible rotors/calipers that can fit on these hubs, a fella is selling some celica (he thinks RA40) brakes which he reckoned looked similar to jdm brakes and said they may possibly fit..
    Cheers for any input,
    Deeken.
    Mark
    go to the ajps site and buy the rx7 caliper adaptor, civic discs and rx7 calipers and bolt it all together. It might cost a bit more than piecing random junk together but it will be a million time easier and you won't need to upgrade again.
    only problem is you might want to upgrade the master cylinder at the same time, and the brakes might not fit inside your wheels
    Jan 2011
    Deeken
    Port Macquarie
    Would consider doing that but I don't see the need atm, especially being on Ps and only being allowed to run NA.. was just going to buy some decent pads and some RDA slotted rotors and have a near brand new brake set up..
    Mark
    yeah I run an NA setup and I love my brakes!! if your going to have to buy discs and pads anyway then you may as well spend a bit more and skip the middle step. The main benefit of it that i see is you don't need to do all the research to find out what works, then find it, wait for parts to arrive then discover they don't work right then start over lol
    Jan 2011
    Deeken
    Port Macquarie
    Hmm true, so i got the hubs now, I just gotta get the eg civic discs and rx7 calipers with the adapter?
    Mark
    yep, I would also consider getting a better master cylinder! Have a look at ajps's section for pricing, there are quite a few other setups out there but that one is probably the easiest to get!
    Veteran hachi_dk's Avatar
    Filip
    Jozzaville
    I can supply you with 294mm dba gold series disks (cost me $480), rebuilt rx7 callipers (rebuild cost me $240) and brand new lucas pads (cost me $120) and adapter plates ($300) to suit. All ready to bolt up and everything brand new and unused. Pm me your phone number and I can send you pics.
    $800 for the lot
    Filip
    Jan 2011
    Deeken
    Port Macquarie
    Hey guys, I managed to find myself a set of jdm brakes thinking these will do unless i start doing track work etc..
  1. Lower Control Arm- Measurments & Compatibility
    By hitoriko in forum Technical - Articles
    Last Post: 2nd July 2012, 02:36 PM
  2. ae86 hubs, brake brackets/brake disk shields the same as ke70 ones?
    By Sprinter Freak in forum Technical - Questions
    Last Post: 12th October 2011, 04:47 PM
  3. Modded loom to suit 86, compatibility?
    By willa in forum Technical - Questions
    Last Post: 28th March 2011, 07:09 PM
  4. WTB ae86 aus spec drum brake hand brake cables
    By hinricp in forum Cars or Parts Wanted
    Last Post: 19th November 2010, 08:59 PM
  5. t18 compatibility
    By bigm in forum Technical - Questions
    Last Post: 25th June 2009, 11:21 AM
