Results 1 to 2 of 2
Thread: Speedo stopped working
    Veteran willa's Avatar
    Will
    Northern 'burbs
    Default Speedo stopped working
    As per the title, I jumped in my at the other day and when I started to drive, noticed my speedo had stopped. I had driven it that same morning without a problem and I hadn't given it any hell that morning or anything.
    The car is an ae71 with 4age and t-50. I've got under and pulled the cable out from the gearbox, gave it a wiggle then put it back in with no luck.
    I'm just wondering a few things:
    How many things can actually give way/break?
    How hard is it to change a cable on the dash end of things?
    And is there a way to pin point the non-working component?
    Cheers, will.
    SuperFunHappySliders
    SR's are ghey.
    Senior Member DR86FT's Avatar
    Kaan
    Emerald
    Pull use dash cluster out go for a drive and see if the cable spins or get a drill connect it at gearbox end see if ur speedo works. Also check the cable hasnt snapped inside the speedo cable sleeve
    Hope this helps
  1. Replies: 11
    Last Post: 30th January 2011, 03:56 PM
  2. Best way to get speedo working right?
    By haydenz in forum Technical - Questions
    Last Post: 14th September 2009, 09:45 AM
  3. H/U stopped working
    By Will(SPA50) in forum Technical - Questions
    Last Post: 17th January 2008, 09:18 PM
  4. ae86 with 4agze has just stopped has nothing help
    By shaun2 in forum Technical - Questions
    Last Post: 16th July 2007, 11:23 AM
  5. speedo not working in adm sprinter
    By kali_man_tan in forum Technical - Questions
    Last Post: 15th June 2007, 08:56 PM
