Results 1 to 10 of 12
Thread: Differential Identification
    Apr 2010
    Michael
    Cebu City
    Cebu
    Philippines
    Default Differential Identification
    Planning on upgrading my differential for KE70 BT. I've seen two kinds of toyota differentials here in our wreckers. Both are in coil spring configuration. Anyways, just want to know what toyota differential series are these:
    Which one should I use? and which one bolts on to the KE70?
    1983 Toyota Corolla GT Model
    Veteran blake.'s Avatar
    Jun 2009
    Blake
    Penrith
    Both look like t-series to me. I couldn't tell you what they are from tho.
    bursting ovaries since 92'
    Apr 2010
    Michael
    Cebu City
    Cebu
    Philippines
    So T-series differentials have different kind of carriers? 1st one is from a RT140 Corona and the 2nd one is from a X70 Cressida.
    Jun 2009
    Blake
    Penrith
    well a t series is a banjo type diff, with 10 bolts holding the center in. if its is from a corona or cressida it wont bolt into a ke70
    t series from a jdm sprinter or a te72 (t-18) will bolt in with the tailshaft and handbreak cables from the car you pull the diff from.
    Bryan
    Waterford
    Tramore
    Ireland
    Top looks like an AE86 unit. Note the long stud at the 7 o'clock position
    Apr 2010
    Michael
    Cebu City
    Cebu
    Philippines
    still need pictures to identify "t" and "s" series differentials.
    Gunner
    second one is an e series
    Ok
    Seamus
    Milton
    T-series (and other diffs) have 10-bolts holding the diff to the housing - like both pictured
    S-series only has 8
    ^ Clicky clicky!
    Apr 2010
    Michael
    Cebu City
    Cebu
    Philippines
    wait i meant "F" series diff. Need pics of the pumpkin/carrier of "T" and "F" series diff.
    Gunner - you 100% sure thats a "E" series diff?
    Veteran slide86's Avatar
    Huw
    Hills
  1. Differential Gear Ratio
    By mikare in forum Technical - Questions
    Last Post: 16th September 2014, 08:49 PM
  2. How a differential works
    By oz_eight6 in forum Technical - Articles
    Last Post: 28th July 2011, 02:21 PM
  3. Differential Gear Ratio
    Last Post: 23rd September 2010, 10:22 AM
  4. differential oils
    By hachi_dk in forum General Topics (No Technical Questions)
    Last Post: 28th January 2010, 09:49 PM
  5. Advantages and disadvantages of a locked differential...
    By PuGZoR in forum Technical - Questions
    Last Post: 2nd November 2006, 01:45 PM
