You can get away with this just make sure you
* check for the amount of wear in the bores (cant remember the max tolerance in a 4age off my head)
* Do not leave the crank in the motor honing puts all sorts of shit everywhere
* Do not use a ball hone they are useless.
* Check wear on crank get linished (or ground if required) new bearings, make sure the thrust tolerance is correct. It is worth every cent.
* yes number and order everything and i saw no mention of new rings?
* lube everything up with decent assembly grease and prime the oil pump. make sure it is working properly!
* use a decent running in oil.
that to me is a basic re-ringer, it will cost a couple of hundred more to get bearings and crank done but it will last you like a proper engine if bore tolerances are in spec.
