what does the small lisst of mods include?
is it a map sensor or afm engine (bigport or small port)?
hey guys
im looking at putting a 4agze into a AE86, small list of engine mods. want to run a Haltech full ECU, im unsure if i should or need to run a timing adjustment module. so my question is is it work the money in the way of gains and tune ability?
cheers guys!
MAP, small port. was told AE101 gze
mods included- larger crank pulley, cams (think 270degree), injectors, massive FMIC (going to run twin TB set up), unsure if im going to use ZE manifold or NA or custom, adjustable cam gears, extractors, proberly MSD LS1 coils, lightened flywheel, bottom end blanced. larger custom sump.
thats all i can think of for now!
Oh, the irony
Thread moved to the correct section...
Sort answer - No!
Long answer - You're doubling up on expences & adding another means of adjusting the timing on top of an already adjustable Haltech ECU.
Are you talking about a CDI rather than a timing adjustment module?
