Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
Thread: 4ac cutting out
    Khai
    Unhappy 4ac cutting out
    hey guys, being this my first real car, i having trouble learning to fix things hahahaha. anyway, not sure if all cylinders are firing, and the engine cuts out when i stop or sit in neutral. wondering if anybody with good experiences with a 4ac or anybody knowledgeable could come and have a listen/look. can supply some beers and a bbq or something, jsut would be great as being a UNI student, money is slow.
    regards in advance, Khai
    Veteran blair's Avatar
    Blair
    SEQ
    Just turn up the idle screw alot... what revs does it sit on before it dies?
    Khai
    ive slammed all the screws, it revs high around 1500+, had it idling find on 900, then i reversed out fine but as soon as i drove and got to my first stop sign.........cut out.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    because this is a thread about you asking for someone local so I have moved it to your local section
    Khai
    thanks sam =]
    Khai
    okay so update, fucked around with idle screw, so it idles around 600 and doesnt cut out anymore, but now i get a massive flatspot when accelerating at the start. any ideas?
    Alex
    St Lucia
    Idle mix screw?
    Khai
    like ill sit in neutral and get it so its out of the flat spot and hold the accelerator on 2k rpm, it will rather quickly just go 1800..2000.1800.2000.1800..2000
    Stern but now fucked off...
    May 2005
    Nick
    Could be losing spark, or fuel
    Checked Sparkplugs?
    Checked Ignition leads? Distributor cap??? Coil ?
    Checked Fuel filter? Fuel Pump???
    Khai
    no. i think one cylinder is miss firing. im really new to all this and no nothing, trying to learn from forum asnwers from people who talk like i know what they are saying half the time. hahahahaha. just put new ngk plugs, nothing. might try leads but they r newish. when i look at a jet inside the carby throat, i see it kinda of plurting fuel when in those flat spots.
  1. Spring cutting?
    By x744 in forum Sydney & NSW Events and Discussion
    Last Post: 22nd July 2012, 12:51 AM
  2. 20v down on power and cutting out
    By sprinters_r_mad in forum Technical - Questions
    Last Post: 23rd June 2008, 08:58 PM
  3. cutting down shifter
    Last Post: 6th May 2008, 01:25 AM
  4. 4ac randomly cutting out at idle
    By Bobomacho in forum Technical - Questions
    Last Post: 25th February 2008, 10:07 AM
  5. What you get for cutting the apex
    By gumbie in forum Toyotas in the Media
    Last Post: 9th October 2005, 07:58 PM
