Results 1 to 8 of 8
Thread: gay creaking but cant locate it on my 86
    Aug 2010
    Sutho Shire
    Default gay creaking but cant locate it on my 86
    ive just finished a lil build and tidy up on my new 86,last thursday taking it for a drive on some decent roads the right side front wheel area developed a creak so the next day i put in new wheel bearings with loads of grease and adjusted them nice and while it was up i installed my new bc gold series coilovers to the front.Taking it for a test drive it drives amazingg compared to before but still has a creak comming from drivers side front wheel area,i checked everything is tight checked sway bar and all other bushes and they are all new looking and no play,checked bolts for cross member,it dosent effect driving but shits me ,dose anyone have any ideas or is there something else i should be looking at or is it part of owning a old car haha,it never made this noise before a drive last thursday night
    Veteran trikzlane's Avatar
    Mereki
    Badassville
    mostly likely LCA bushes or ball joint
    ~KEEP DRIFTING FUN~
    Senior Member Stain's Avatar
    Derek
    Far North
    i once had strange creak coming from the front suspension... all components checked out fine...
    it ended up being a longer than usual bolt sticking thru the strut tower and _just_ touching the spring under certain load/cornering.
    not saying thats what yours is, but doesn't hurt to check
    Stern but now fucked off...
    May 2005
    Nick
    Needs more enter key.
    FYI, enter key looks like this
    Mark
    woo is it that time of year again? LOL
    Veteran slide86's Avatar
    Huw
    Hills
    remove the lower control arm bolt, pull the arm down, apply heaps of grease to the bush where it rubs on the crossmember. Refit the arm and bolt. see how you go.
    repeat the same process for the castor rod bushes, perhaps just spray them with rp7 instead of trying to remove the rod.
    if you spray a bush and the noise goes away, then you have found the culprit and you can grease it up properly.
    Aug 2010
    Sutho Shire
    thanks for that worked great its all gone,sorry bout not using enter i never knew i was ment
    to but will now
    Akio
    Mt Haruna
    Japan
    all AE86's creak/squeak in some way.
    HTH
  1. Drifting is gay?
    By Mickey H in forum Offtopic Discussions
    Last Post: 12th March 2009, 06:23 PM
  2. gay
    By Ade_Mc in forum Toyotas in the Media
    Last Post: 10th December 2007, 12:11 PM
  3. 2 I AM GAY vids
    By Klutch in forum Toyotas in the Media
    Last Post: 8th December 2006, 02:22 PM
  4. Gay Twinky Boy
    By Gay Twinky Boy in forum General Topics (No Technical Questions)
    Last Post: 17th October 2006, 10:02 AM
