KE30 tubes, RA40 ends... you get more then enough adjustment...
Well maybe the RA60 bits had been swapped previously. I was thinking of getting some hex bar, like 19mm hex, and making nuts with a huge hole, and welding them on. Just a fine detail I may or may not end up doing.
I think the standard solution we now know is to use short rod ends from a KE30, KE55, RA23, RA40, RT132, XT130 (all the exact same part), and use threaded tubes from RA23, RA40, XT130 (all the exact same part), and tubes from a KE30 work also.
Just trying to help... doing this myself also. The pictures are great.
Anyone get the License plate of that B& Hammer?
or t18 tubes
Do you mean LCA's? It's pretty sketchy from memory, that's why people change them to longer options as they have more thread.
marvis.
yeah whoops typo on my end
