Could i trouble some/any of you to take some photos of your rear dizzy (as CAS) setup? Specifically, your clearance between dizzy and heater line.
I can only JUST fit my dizzy in .. without a cap on it. I am slightly concerned, thanks.
gearbox spacer helps but its very tight still
the dyno pull to 300rwkw
I'll take some photos when I get home
I no longer have pictures however what you need to do is cable tie your heater hoses to the metal lines on the firewall and tuck them right in. It also helps to undo the clamps and put the tensioner out of the way. Doing it this way I have an easy 3 to 5mm off the Kaizen cap with the trans spacer.
wont a 7a be a fair bit different to most ppl's pics?
about 12 to 15mm different isnt it![]()
06/07/2011
yeah something like that. Is that not a fair bit??All depends on tolerance I guess.
