checked fuses?
So my AE86 cluster lights aren't working, the door light/handbrake/charge light are all working...also my climate surround lights don't work (maybe globe or something...or linked to my problem)
Thanks in advance!
checked fuses?
check fuse
check light bulbs from the cluster, best use a test light cause if it shines, it should work
check the earthing wire, mine was full dead and found it was a dodgy earth wire leading onto the cluster..
dose
