Results 1 to 3 of 3
Thread: AE86 cluster light not working
    Senior Member LEVIN86's Avatar
    Nam
    Westside
    Default AE86 cluster light not working
    So my AE86 cluster lights aren't working, the door light/handbrake/charge light are all working...also my climate surround lights don't work (maybe globe or something...or linked to my problem)
    Thanks in advance!
    Oct 2010
    Dogan
    Tulla
    checked fuses?
    Veteran Rice86's Avatar
    Richard
    Liverpool
    check fuse
    check light bulbs from the cluster, best use a test light cause if it shines, it should work
    check the earthing wire, mine was full dead and found it was a dodgy earth wire leading onto the cluster..
    dose
  1. Replies: 1
    Last Post: 29th June 2011, 04:24 PM
  2. working adm cluster
    By redsprinter in forum Cars or Parts Wanted
    Last Post: 4th January 2010, 12:09 PM
  3. light not working
    By fozz in forum Technical - Questions
    Last Post: 25th September 2007, 02:19 PM
  4. REVERSE LIGHT NOT WORKING
    By Eddy in forum Technical - Questions
    Last Post: 12th July 2007, 02:19 AM
  5. Cluster help ! not working
    By jase ek in forum Technical - Questions
    Last Post: 9th June 2007, 12:45 PM
