Page 5 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 LastLast
Results 41 to 50 of 133
Thread: Herbert The Panel Van
  1. #41
    Apr 2010
    Hills
    i think ill get some thing pretty close to the 104 or some thing in between the 240. i will be doing a mild head job just so the exhaust ports match the extractors and give it a polish to. maybe even get the fly wheel lighted just a little bit. pretty much just to make it a nippy engine wiht out being extreme.
    the carbie has been fully reconditioned for me im not sure what he put in it. but hes a smart guy so i doubt he would of built it wrong
  2. #42
    Stern but now fucked off...
    May 2005
    Nick
    Don't polish the ports on the inlet side. Some of us have found that when fuel hits a mirror finish, it turns into beads and dribbles rather than smashing into a rough surface and atomising properly.
    Exhaust side is fine to polish if you want... lol.
    Run some Holden 202 valve springs - 4K valve springs just cannot handle high revs and you'll be losing easy power there...
    You'll also gain more easy power by balancing the internals of a 4K. They really don't like being taken over 9000 RPM very often unless you have balanced them. Mine used to hit 9200'ish a couple of times a week.
    But as you mentioned, the head is by far the most restrictive part of a 4K engine. I'm pretty sure that N/A even with massive porting and balancing most of the highest powered 4K engines max out at the 150-160HP (at the fly) range. Forced induction should get you over that (up to 200HP if you do it right). Theres a bloke on Rollaclub who managed to fit a 4AGE twincam head onto a 4KC - Epic swap. HEAPS of induction air flow with less restriction that the crappy K series head, with the instant benefit of quad throttle bodies & EFI wheee...
  3. #43
    Apr 2010
    Hills
    so if i get the inlet ports done, will they be smooth or can you get it done in away i guess you can call it ruff?
    is there any good article that you know of about balancing and blueprinting around any where? i have been trying to research out it but haven't really come up with any thing that helped out to much.
    i wish the laws weren't gay in adelaide. rather build a beast of a 7age turbo haha
  4. #44
    May 2005
    Nick
    Normal porting usually leaves stuff pretty rough after the burr. thats OK, the "polishing" part where it gets cleaned up to a mirror finish = not worth it.
    Engine balancing
  5. #45
    Apr 2010
    Hills
    explains alot, but with stock pistons and such. what happens if one of the stock ones is out by 20g's? what do they do?
  6. #46
    May 2005
    Nick
    If your pistons are out by 20 grams you have big problems, LOL
    We're talking a couple of grams at most
    All they do is weigh everything, and reduce the weight of all the heaviest ones down to the same weight as the lightest one...
  7. #47
    Apr 2010
    Hills
    haha yea that was just a example.
    might have to look in to it sounds like a good investment
  8. #48
    Apr 2010
    Hills
    got the carbie on today. starting to get some where got a question about the fuel lines though
    am i right?
    hopefully have it running tomorrow night
  9. #49
    May 2005
    Nick
    According to the photos of my KE70, mine was plumbed in differently.
    Still trying to find more pictures...
  10. #50
    Apr 2010
    Hills
    cant see the photos i think i have worked it out now. im calling the carbie guy tomorrow jsut to make sure
  1. MoNsTaR's Panel Van vanvan van van vanvanvan van
    By MoNsTaR in forum KE70 / AE71 Owners Forums
    Last Post: 15th December 2011, 08:48 PM
  2. ke70 panel van
    By dehney in forum Cars or Parts Wanted
    Last Post: 5th December 2011, 03:27 PM
  3. Replies: 14
    Last Post: 16th August 2010, 08:39 PM
  4. ke70 PANEL VAN
    By todd in forum Cars for Sale (Toyota Only)
    Last Post: 20th July 2008, 05:28 PM
  5. Panel van project
    By matt99 in forum KE70 / AE71 Owners Forums
    Last Post: 20th May 2008, 01:03 AM
