Page 46 of 158 FirstFirst ... 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 96 146 ... LastLast
Results 451 to 460 of 1580
Thread: 80's Coupe
  1. #451
    E-Famous (Remeber your roots)
    So whats the lowdown on the rimzz.
    Hit me up if you need a hand with anything.
  2. #452
    Veteran Robo86's Avatar
    Rob
    umm getting some 14' gravel white te37s when they pop up
    machinist rung today, everything nearly done.. one small thing the new pistons we have are actually 0.5mm oversized so hes boring the cylinders to suit. kinda didn't wanna do that but oh well the 0.5 shouldnt make to much a of a difference to comp ratio or final displacement should be better overall hopefully! final comp ratio is looking to be about 11.4:1
    thanks for the offer marv.
    http://shirtstuckedin.com/
    my corolla
    Bosman Wholesale Tyres
    3274 5374 - Roy
  3. #453
    Awesome. What size and offset would you be looking at?
    The bro's should be done this week also.. Then I get to throw it all together..
  4. #454
    Rob
    7j 0 going all ueo d1sl style lol.
    nice work with ur bro's.
    my corolla
    3274 5374 - Roy
  5. #455
    Veteran Touge Boy's Avatar
    Modbury
    those TE's sound dope.
    Ive probably missed it somewhere in the thread, can you explain how your front guards were cut? they were done to be super-low and still have clearance?
  6. #456
    Rob
    rear guards - flare section cut off, ae82 front flare section (20mm wider) welded on ~20ishmm up.. means u can lay rail and not rub to much.
    fronts - stock fenders flared then trimmed back ~15ishmm higher, once again so u can go low.
    talk to slydar more about it if u want.
    my corolla
    3274 5374 - Roy
  7. #457
    oath sounds hot.
    i have te37's in that exact size an offset. but they are bronze
    they are baller light. white ones will look rad on your car though.
  8. #458
    Rob
    Yer the te37 idea is out the window for now, cant afford/rare to get gravels in that size.
    Anyway some good news for the day, picked the motor back up from the machinist. Everything looks awesome, here's what i got done:
    -All parts acid cleaned
    -New stainless welch plugs
    -New rod bolts & Rods re sized
    -Rod small ends honed to make small port pins fit (full floating)
    -Block bored & honed 0.5mm oversize, to suit new hi-comp small port pistons.
    really happy with how things are going
    my corolla
    3274 5374 - Roy
  9. #459
    Ok
    Seamus
    Milton
    in before someone else says it -> nice towel!
  10. #460
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    cool, looks like all the gear I have in my garage courtesy of Seamus (- the pistons/rods)
    Look forward to the outcome man, you seem to be traveling well... so keen to hear some first hand 7a experience.
    BENT MECHANIX - Garage 20:
  1. 80 Series Landcruiser
    By sundee in forum Cars for Sale (Toyota Only)
    Last Post: 21st February 2012, 09:51 PM
  3. Trd lip $80
    Last Post: 18th July 2009, 02:07 AM
  5. intercooler $80
    By ae71 4 lyf in forum Car Parts For Sale
    Last Post: 12th September 2008, 10:28 AM
