i hit all the spots with a wire brush so i could see how much it had actually eaten away, then cut the area's out and made plates and welded them in and grind it back welded abit more and then bog
<<<<<<<<<<will become your best friend
I just wanted to know how people go about getting rid of all the rust in there hachi/ke they all rust in the same spots and mine has rust everywhere so I don't care what you've fixed i just wanted to know what methods people are using on different parts of their car I’ve done a bit on my hachi and still have lots to do I’ll put some pic’s up later
cut and shut, want a pile of pictures?
the rust in the back of my hachi was pretty bad
first i just cut out the beaver panel 30mm above the floor and then removed the lower section completely
i had this 90deg piece made up at a normal fabrication shop it’s the same thickness as what was removed, because its so thin I was able to easily bend it to suit the radius of the rear then it was just a matter of slowly welding it in without warping anything as for the lower section I was able to buy the panel from Toyota for $350 it just has to be spot welded in and it done ill get some more pic's when it’s done if I’m doing anything wrong or you think I could do something different tell me as I’m teaching myself and I am in no way telling you how shit should be fixed this Is just the way I’m doing it
yes i want pics
pleasee?^
righto sam, next time flights are cheap im paying you to come up and fix my hatch!
Nice work with the repairs sam.
I wish I had a welder and the skills to tackle a job like that.
Coming down to Sydney soon?![]()
