heres a wet sump cut out
heres my standed sump and rack clearence (for those playing at home)
so if you go abit further forward and down you might get it in.
You can fit a wetsump + w58 if you cut the webbing out to clear the rack... and no tunnel massaging. It's really close though.
The oil pan will be 1.5-2" below the crossmember so you'll need a good bashplate if your worried about ripple strips or offroading.
Andrew
kes come standed with a lift kit
yeah..... there is no way to reasonably do it like andy has without dry sump.... mine could have dropped about 50mm from where it was.... but then i would be 80mm below the crossmember lol
06/07/2011
