Results 1 to 3 of 3
Thread: Nissan tech. SR20det is there a difference between red top and black top ecu's/looms?
    Veteran slydar's Avatar
    Dimitri
    Default Nissan tech. SR20det is there a difference between red top and black top ecu's/looms?
    i own a s13 sr20det red top. i want run it on factory engine managment. just trying to shop for a loom/computer. im assuming i can definately run it on black top engine management with the loom from the same car.
    but are red top looms compatible with black top ecu's and vice versa? what about auto and manual?
    78's
    Veteran Skylar's Avatar
    Ken
    You mean S13SR black top right, not S14SR? In case of S13SR, yeah, all fine except type-x which have different pinouts on the same blue plug. S14SR ECU has totally different plug(grey) so you need to run the S14SR loom but will run the engine fine as long as you match AFM and injectors to ECU and o2 sensor to a lesser extent. S15SR is same as S14SR but coils have built in ignitors.
    Yeah, just run whatever ecu plugs into whatever loom you have.
    auto to manual is fine. The only thing I noticed is auto ecu will push the car along at idle happily whereas the manual one struggles along at 500rpm pushing the car up the slightly inclined driveway. Both times in 2nd gear with no throttle input.
    Anthony
    yeah any blacktop loom will be fine, AT or MT. just as long as its not lumpy top. if it is will need some slight mods.
  1. CHEAP s13 sr20det (red top) and 15x8.5 longchamps
    By slydar in forum Car Parts For Sale
    Last Post: 8th October 2011, 06:37 PM
  2. VIC 1994 Sileighty Manual SR20DET Black Top
    By 1500sr in forum Cars for Sale (Not Toyotas)
    Last Post: 5th June 2011, 11:44 PM
  3. sr20det red top stripped to rebuild
    By aussyboyz in forum Car Parts For Sale
    Last Post: 28th September 2009, 12:37 PM
  4. sr20 red or black top
    By Fozz in forum Cars or Parts Wanted
    Last Post: 19th December 2008, 08:59 AM
  5. sr20det black top
    By tunney in forum Car Parts For Sale
    Last Post: 12th June 2008, 09:20 PM
