either will fit but you will need the carrier and crown and pinion from a live axle set up ,then you also will need new side bearings and gettting it set up .i would go 1.5 if you have a grunter of a motor and 2way with not much power
Hi Guys,
I've got a locked tarago diff and want to go to an LSD. Does an Altezza LSD fit without any mod's?
Am looking at the KAAZ 1.5 way or TRD mechanical diff
Cheers!
Many thanks
you sure the carrier and pinion is required from the altezza diff too? i thought you could use the tarago pinion and crownwheel on the altezza centre?
also crown wheel and pinion sets are also matching ,you cannot mix and match as they have been shaved to match each other .same as gear box ratios
yeah but the centre can be changed
can anyone confirm this?
Do you need altezza pinion and crown to fit altezza diff centre to F series?
No. Any F-series R&P will work. Just a matter of getting the right bearings.
Andrew
