Hi, Was hoping to get some ideas of what might be wrong with my car.
Its a 4agte, with external wastegate. It has a razorback ecu.
The turbo manifold manifold cracked and the car sat around for about a year. I then had a new manifold built and I put it back together.
The problem has started since then.
It has become very difficult to start, cranks over but jut won't kick over. After alot of patience and persistence it will eventually start.
The car can sit and idle for approximately 10mins fine until it appears to flood and stall.
If started again, (also very difficult) it can be driven around normal and will drive fine.
It can be driven hard and goes great, doesn't miss a beat, not a single problem. However, when coming to a stop it's as if it floods itself and will stall unless the rev's are held up.
I've tried adjusting the idle speed, emptying the fuel tank, at first i thought it was just bad fuel, had the injectors cleaned, tried lowering/raising air fuel ratio's in the computer. Nothing seems to make a difference.
Any help or ideas would be greatly appreciated.
Thanks Jason
