Results 1 to 9 of 9
Thread: 86 jdm tank installed, but now car wont start up?
    Dave
    The Ghetto
    Default 86 jdm tank installed, but now car wont start up?
    hey guys ive just recently installed a jdm tank into my sprinter however it appears now that the car wont start up?
    Ive checked:
    1) All lines and that they are connected correctly
    2) Prime the fuel line of any air
    3) check pump if it is actually even working (which it is).
    4) Spark plug wise the car did not have any issues with it before i installed the jdm tank
    So what could it be? Can you please help me find the root of the problem.
    Muchly appreciated,
    Dave
    Dave
    The Ghetto
    also car turns over just doesnt fire up
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    getting injector pulse and spark(yes you might of had spark before but you might not now, just better off checking)
    what wires are you running the pump off???
    Dave
    The Ghetto
    yes i will check that. Nah tank isnt connected up yet just tested it to see whether the pump works
    Michael
    Crimebrook 2749
    so what are you powering the pump from???
    Veteran Rice86's Avatar
    Richard
    Liverpool
    does it have fuel in the tank ?
    dose
    Senior Member Stain's Avatar
    Derek
    Far North
    How did you have the car working previously (assuming ADM tank with a inline high-flow pump)? What have you changed to install the JDM tank?
    Really not much that can go wrong... disconnect the fuel line at the rail to see if you have pressure?
    Also check that the correct lines are connected to the "in" and "out" of the rail... don't want to be forcing fuel in the wrong way.
    Dave
    The Ghetto
    hey guys yes the tank does have fuel in it. Stain: Yes had ADM tank with inline high flow pump. Basically i chucked the adm tank out installed the jdm one in. All fuel lines are correct. Fuel line going into the rails the right way. I have no idea??
    I might have to do another thorough check tmr. Might check pressure?
    Mt Macedon
    Do the basic checks: does it have spark, are the injectors clicking, etc.
    It may be you disconnected something innocent and unrelated in the process and forgot about it (I do that all the time anyway).
  1. car wont start.... help!
    By 20v ae71 in forum Technical - Questions
    Last Post: 17th March 2011, 08:40 PM
  2. car wont start
    By james86 in forum Technical - Questions
    Last Post: 6th September 2008, 02:54 AM
  3. MY CAR WONT START
    By Troy09 in forum Technical - Questions
    Last Post: 1st August 2008, 09:50 AM
  4. car wont start
    By The Enthusiast in forum Technical - Questions
    Last Post: 21st August 2007, 12:05 AM
