Page 26 of 37 FirstFirst ... 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 ... LastLast
Results 251 to 260 of 361
Thread: My KETO project
  1. #251
    Sep 2010
    Dan
    WEST BRISBANE
    austraila
    hey mate love the interior. wat did u do to get the interior black. it looks bad ass
  2. #252
    ryan
    thanks man, used VHT black vinyl die i the vinyl parts and matte black paint on the plastics.
  3. #253
    ryan
    ok so got the gearbox and diff back today. The diff is sweet, just needed a bit of adjustment and is tight as now. Bad news was that my box was gone
    so have been hunting around for a new one.
    Am unsure what to get tho, the guy at the gearbox place said that it broke because of constant clutch dropping. And the next box is going to get the same treatment so don't know whether its worth going for something like a w55? i know most people only use them for big power set ups, but if my next t50 isn't going to last very long maybe its worth it for more reliability. what do you guys reckon?
  4. #254
    Gunner
    Build it so it doesnt break, but mechanical sympathy goes a long way young ryan.
  5. #255
    ryan
    yea thats what i was thinking that but surely t50 will hold up with standard power drifting?could it be that my old box was flogged out and just finally let go?(the box was fairly hard to get into 3rd and would crunch occasionally). haha mechanical sympathy and drifting don't go together.
  6. #256
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    build one, backlash and shit clearances will cause things like that to happen, a lot of people running t50's behind 4ages, that cop a lot more abuse then yours (can garentee it)
    i know someone with a t50 that has fucked bearings, if you need something cheap for parts
  7. #257
    ryan
    my diff only had a fairly small amount of backlash, but yea might of been that. ok so a good condition t50 should be fine behind a standard t50? cheers for the offer man but i think ill just get a new box and if that goes ill probs just fork out for w55 conversion.
  8. #258
    Michael
    Crimebrook 2749
    anything with mating gears can have back lash(eg your box), having a large clearance or backlash , whne you clutch kick it smashes the gear together harder, smashing them
    like if you go to undo a bolt with a spanner, you put your weight on it doesnt crack the bolt, so you hit it with your hand instead of jsut pushing it, and it cracks(comes undone) exept your detinating gears XD
  9. #259
    ryan
    ohhh i thought only diffs got backlash, cheers for the info didn't think there was that much play in the in the box, but then again i never really properly checked it so could have been that.
    Guess ill just grab another t50 then.
  10. #260
    ryan
    Got a set of wheel nuts for the car, they're only cheap steel ones. But the way i see it is that there going to get wrecked with constant tyre changing so no point getting alloy expensive ones.
  1. Daves KETO Project
    By Dave in forum KE70 / AE71 Owners Forums
    Last Post: 26th August 2007, 04:46 PM
  2. Dirty Keto dori project
    By Brendo in forum KE70 / AE71 Owners Forums
    Last Post: 9th August 2007, 03:49 PM
