Page 21 of 37 FirstFirst ... 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 ... LastLast
Results 201 to 210 of 361
Thread: My KETO project
  1. #201
    Gunner
    Good shit Ryan, sort out when you want to get into it, I'll get some tyres, and an axle in my heap of shit (no guessing whats happened there haha) and we'll get stuck into it.
  2. #202
    Gone
    Joel
    Picton
    mate ill give you a hand when you get your stuff sorted and your mind made up
  3. #203
    ryan
    ok so haven't really done much with the car, just got a few parts for it. was moving the car the other night and found the stud i thought i snapped( was sitting in between the brake backing plate and the disk)
    new wheel stud and nut and a genuine toyota rear main seal (ordered in a new head gasket, am picking it up tomorrow)
    also damage from the tyre coming off
    still have to get a new set of spark plugs and a new gearbox mount. will probs get some work done on the car in the coming week.
  4. #204
    ryan
    ok got a bit of work done on the car today. picked up my head gasket and some gearbox oil.
    started by taking the shifter off, taking the shaft and taking some of the gearbox bolts off. (some were stuck on, too much loctite. so am leaving them over night with some wd40 on them)
    hoping to get it done and have it back together by tomorrow evening, then its onto taking the head off
  5. #205
    ryan
    thanks man, haha sounds like you've been having to much fun in the vl sounds good.
    cheers dude, much appreciated
    are either of you guys free on the weekend sometime? a bbq could be arranged.
  6. #206
    Gunner
    Pretty flat out this weekend, will see if i can free up some time.
  7. #207
    ryan
    if you could that would be great but if your too busy i understand. shoot us a pm if you get any free time.
  8. #208
    ryan
    have been a bit lazy lately. Gearbox still isn't out of the car, need to get the right sized socket piece for two of the gearbox bolts(will get tomorrow).
    Did get round to pulling the intake off and draining out the coolant.
    found out that i had a break in my intake gasket, so have to get a new one of those. which type of gasket should i be using, the broken on or the un broken one? i'm not running tvis.
    also picked up some ae82 temperature sensors, so hopefully this should fix my running rich problem.
  9. #209
    Gone
    Joel
    Picton
    Just saw your posts, I was away over the weekend so would have been no help.
    I'd just ditch the tvis gasket and run the "broken" one.
    But a new one of course.
  10. #210
    ryan
    all good man no problem yea that was what i was thinking, will grab one at toyota tomorrow
  1. Daves KETO Project
    By Dave in forum KE70 / AE71 Owners Forums
    Last Post: 26th August 2007, 04:46 PM
  2. Dirty Keto dori project
    By Brendo in forum KE70 / AE71 Owners Forums
    Last Post: 9th August 2007, 03:49 PM
