Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
Thread: Custom Steering Rack Mounting
    Veteran bigm's Avatar
    Gold Coast
    Default Custom Steering Rack Mounting
    Hey Guys,
    Here is the story,
    My mx73 had powersteering from factory, i removed it and dodgyily put in a ke70/ae86 steering rack, that doesnt line up well at all. but has done the job for a while now.
    Now what i want to do is solid mount the steering rack housing to the cross member for the following reasons
    -the current mounts do not line up
    -it is a track only car and i want direct steering and dont see the need for bushes
    The rack housing will most likely be welded to a piece of steel that then bolts to the cross member for removeability if required. I will be doing the fab myself.
    Now my questions here that is a bit technical, Where is the ideal place to mount the rack. things i have considered i have to work with.
    -Needs to be centered
    -Should move forward than a factory rack would (to reduce bind (its a drift car)
    The things i dont know.
    -what height do i mount it (in relation to the control arm bolt?)
    -how mounting it will affect bump steer/ scrub radius etc
    If anyone has any good information to help that would be dandy, Google didn't help much but i plan to keep looking, im asking here for some experience who might know what they are on about
    I also dont have the original rack (no idea where it went to be honest) so i cant take measurements from that.
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    dont you move the rack back, so that the tierods/rackends dont end up inline(straight) with the steering arms/knuckles causing binding???
    (thats what the nissan guys do)
    Gold Coast
    if u move the rack back they will bind sooner because the straight line will be achieved with less lock...
    Veteran Skylar's Avatar
    Ken
    Ehh, can't be bothered 'splainin'. Ask whatever you don't understand.
    Note: Ackerman is only evil in the way of drifting.
    Michael
    Crimebrook 2749
    yea i just sat down and drew it up and thought WTF!, i swear thats what loyd smith and beau have done, and others
    Ken
    Oh and zero bump steer isn't possible while you have a radius rod. You can minimise it by having the radius rod parallel to the ground.
    Gold Coast
    I assume the first picture is when the cars suspension is loaded, if so thats all good.
    understand the bindining all good.
    the ackerman getz me, is it something i can rectify by the position of the rack or is it to do with the knuckles used?
    But that gives me a great place to start thanks man
    Gold Coast
    and can u please elaborate on the radius rod- what it is and just a bit more info?
    CHeers
    May 2010
    Nick
    Ipswich
    Ackerman is on the knuckle. Sorry using Nissan talk.
    Rack doesn't affect Ackerman.
    I don't know what a radius rod is
    Michael
    Crimebrook 2749
    acker man's is in your arms, yes you should be able to get arms that dont have it (T3 do them for ae86/ke's) its pretty much when you turn the inner wheel turns less then the outer one(as one has a greater distance to travel)
  1. Replies: 2
    Last Post: 3rd September 2012, 11:04 AM
  2. Replies: 1
    Last Post: 3rd July 2012, 05:33 PM
  3. rack end and rack bush for ae86 power steering rack
    By quoccy in forum Cars or Parts Wanted
    Last Post: 28th June 2008, 12:58 PM
  4. Steering Rack to Xmember Mounting Issues (Passenger Side)
    By Project_dorifto in forum Technical - Questions
    Last Post: 26th November 2007, 10:26 PM
