Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Thread: 20v to 16v conversion
    Adan
    Oxley Park
    Default 20v to 16v conversion
    Car - ae86
    motor - 4age
    use - driving
    problem - brain fart
    personal situation (if applicable)- slightly cold
    Hey,
    I was just going over what parts I will need to buy over the next few weeks for my engine conversion and had a massive brain fart.
    I currently have a silvertop 4age in my ae86, and want to change to a 16v smallport.
    At the moment, Im running a microtech, so the 20v has coilpacks and rwd CAS cover. Im not using the ISCV or any standard gauges at all.
    Should I be able to pretty much swap the engines over and just swap it all over to the 16v? Ill be running the itbs on it too, so injectors and everything will be swapped over, Im just not sure about the CAS.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    providing the length is ok for the crank angle sensor and the tps being held on the other side then you should be fine. However the wiring of the crank angle sensor might be different, the plug would be at the very least.
    You can use the same coilpacks and all as the height is pretty good on a 16V, I had planned for a while to make an adapter plate however I am unsure if I will go through with it.
    Adan
    Oxley Park
    Im not so concerned with extending wiring and swapping plugs over.
    Im mainly not sure about being able to make it run off the current microtech settings. Is the 20v CAS able to be swapped into the 16v? Or would I be better getting gze one?
    I think the crank angle sensor is the only difference between the 2 engines I can forsee.
    Senior Member Stain's Avatar
    Derek
    Far North
    The 20v CAS won't go into a 16v... you NEED the one off the GZE if you're going to keep coilpack ignition.
    Also the injectors are different. Can't use 20v ones in the 16v.
    Other than that it should all be pretty straight forward depending on the 20v water system was setup.
    But there will no doubt be changes required in the ECU, doubt it'll run with exactly the same settings.
    Adan
    Oxley Park
    Ah ok, yeah I guess will source a gze CAS then.
    I will be running the 20v itbs, so the 20v injectors should work though?
    I might be missing the whole point you are all making, but I was hoping I could pretty much swap most stuff over and let the computer think it was running the same engine and then get it retuned after its running.
    But it might be easier to use the 16v loom and hook that up to the computer now. Would there be any differences in the microtech itself for the 20v and 16v, or can I just get it retuned to suit after its all in?
    The water system will be redone, its mainly the computer and electrical signal side of things which im not sure about.
    Veteran slydar's Avatar
    Dimitri
    you will just be able to use the stock small port dizzy, internally (as in the CAS) its the same. a GZE cas would be neater but its not necessary. injectors will be your problem. the 20v ones wont fit the 16v rail. 20v is side feed smallport is top feed. if you search the internet/maybe toymods you may find a chart which has a list of toyota injectors. if you can find an injector with the same impedance/CC's that is top feed (even if the cc's are out of 10 to maybe 20%) it will work.
    78's
    Dimitri
    so yes your theory will work you just need to get the right injectors.
    78's
    Adan
    Oxley Park
    Oh now thats good news.
    Yeah I was hoping to use the smallport dizzy, and then make up a cover similar to the rwd 20v ones to get rid of the dizzy cap, and just use it as a CAS.
    If I swap the entire 20v itb setup onto the 16v, wont I be able to keep it all exactly the same i.e. injectors, tps etc
    I thought this would keep the stock 20v fuel rail and associated bits?
    The only thing I will really be changing is the bare engine from 20v to 16v.
    Derek
    Far North
    the heads are too different. you can't bolt the 20v manifold onto a 16v.
    to use itbs on the 16v you need aftermarket adapter plate (like the T3 one) to attach the quads to the 16v head.
    Adan
    Oxley Park
    Yep quite aware of that.
    After some more searching, it looks like it should all work out ok. 20v dizzy, smallport dizzy, gze CAS all seem to be the exact same inside.
    So ill just use the stock smallport dizzy as a CAS and make a cover (similar to the rwd 20v one) so it looks neater.
    Ill use everything else straight off the 20v, sensors, tps, injectors, itbs, the computer wont even know ive changed the engine.
    Only thing I need to get rid of is the vvt wiring, though I dont think its hooked up to the microtech anyway.
    Thanks for the help guys
  1. 20v-16v conversion, engine wont start
    By meadan in forum Technical - Questions
    Last Post: 5th July 2011, 06:34 PM
  2. wtb: syd: rwd 16v or 20v 4age complete conversion package
    By knly06 in forum Cars or Parts Wanted
    Last Post: 16th August 2010, 01:04 PM
  3. RWD 16v Bigport, 20v RWD conversion Kit, quads + sh*tloads more
    By oz_eight6 in forum Car Parts For Sale
    Last Post: 25th May 2010, 10:10 PM
  4. 4AGE N/A Conversion Costs: 16v and 20v
    By Dan_AE86 in forum Technical - Questions
    Last Post: 11th July 2007, 11:21 PM
