Results 1 to 2 of 2
Thread: *EOI* AE71 20v Turbo
    Senior Member blacktopspirit's Avatar
    Brendan
    Eastern
    Default *EOI* AE71 20v Turbo
    Might be looking at selling this to someone that will actually finish it
    AE71 Spirit
    20v Silvertop
    Stock internals
    Converted to RWD and sitting in the car
    T25 Turbo, plumbed in with some amazing pipe work
    Full Exhaust I think it's a 2 1/2 inch from memory, pro job!
    EMS Stinger V3 (needs to be tuned)
    it has been started, but was backfiring so firing order might be out of whack or coils installed/wired wrong, I don't know!
    T57 Supra box with short shifter
    Dellow bellhousing
    G series Hilux diff with from memory 4:7 Ratio!!! converted to 4 stud, running stock drums, Hand brake not matched up yet
    Koni Yellow Adjustable all round
    Whiteline progressive rate springs at the front
    King springs in the rear
    Corona LCA's
    Cusco Camber Tops (not installed)
    LRCA's (not installed)
    Whiteline Adjustable Sway bar front and rear (I think they're both adjustable, I haven't looked for about 5 years)
    this is honesty as good as any top end coil over setup, I only considered changing this setup once and that was for GReddy Coil overs.
    15x7 - 10 Superlights
    Maxxis MA-Z1 never been driven on! (now discontinued)
    Rust isn't too bad, it has it, but so does every other AE out there, it's still registered, but none of the numbers match up, so it would need to be a dodge if you wanted to transfer.
    pretty much just needs brakes sorted out (90% done) I think the clutch needs to be done, and someone who knows what they're doing to sort out the electrical problem, but it will start as is, it just might throw a rod through the block, Trent from Chequered Tuning has worked on this car a lot, and I'm sure would be happy to tune it when the electrical shit is sorted.
    I have spent about $20k over the last 5 years, and this is so close to finished it's not funny! I just no longer have the time nor the patience to work on it, and am looking for something I can just get in and drive! I havent even attempted to work on it in about 2 years!
    I'm open to serious offers or swap, but I warn the tire kicking 10 year olds out there, if you fuck me around I will cut you!
    Located in Monbulk VIC
    Price $have no idea what it's worth so lets say $10000000000k
    there are pictures around here somewhere I think, I'll look for the link and edit this post when I find it.
    Brendan
    Eastern
    Pictures, just ignore the pictures of the 2 crashed corolla's they are different cars
  1. EOI ae71 4AGZE turbo W57
    By armc89 in forum Cars for Sale (Toyota Only)
    Last Post: 5th April 2012, 07:50 PM
  2. Psi20v Eoi, 200rwkw Ke70 20v Turbo Drift Car
    By ae71 kid in forum Cars for Sale (Toyota Only)
    Last Post: 16th October 2009, 05:36 PM
  3. PSI20V eoi, ke70 20v turbo drift car
    By killer ke70 in forum Cars for Sale (Toyota Only)
    Last Post: 25th September 2008, 06:51 PM
