Results 1 to 4 of 4
Thread: Exhaust Flange Gaskets Alternative
    Pat
    Jannali
    Default Exhaust Flange Gaskets Alternative
    Hi,
    I have a AE92 4AGZE (running standard SC12) that I use in a Clubman mostly on the race track.
    I have a problem with the 2 flange gaskets that seal between the standard OEM cast iron exhaust manifold and the down pipe.
    They seal fine on the road but with the high temps I get on the track they are only really good for 1 track session before they start blowing. The 3 studs are in gd condition and I use the toyota std nuts and gaskets. Nuts stay tight and flange stays tight but gaskets still do not last.
    So has anybody found an alternative flange gasket that survives at high temperature, or can recomend alternative material that I can make some from which will survive ????
    I am thinking perhaps solid copper anealed may do the trick ??
    Thks,
    Chrs, pat
    Moderator Sam-Q's Avatar
    Endeavour Hills
    well you could use a the metal gasket off the 20V engine and redrill the two outer holes, I would imagine that would put up a bit of a fight
    Senior Member *E7*'s Avatar
    Dave
    Eastern Melb.
    how about a set of extractors, to get the join further away from the head, reducing the temp it has to deal with
    Glenn ke_70's Avatar
    Clay
    Barossa!
    ^expencive solution
    can you weld on one of those kkr quick release flanges? or is it where the twin secondary pipes bolt up?
  1. exhaust manifold flange design
    By Skylar in forum Technical - Questions
    Last Post: 8th September 2010, 01:13 PM
  2. exhaust flange
    By fozz in forum Cars or Parts Wanted
    Last Post: 23rd January 2008, 03:42 PM
  3. Bigport exhaust flange
    By Robo86 in forum General Topics (No Technical Questions)
    Last Post: 18th December 2007, 01:35 AM
  4. exhaust flange for JDM manifold
    By haydenzz in forum Technical - Questions
    Last Post: 6th December 2007, 11:53 AM
  5. 20v exhaust flange
    By jdmtrueno in forum Technical - Questions
    Last Post: 9th June 2006, 12:43 PM
