Selling my relocator kit and Omori gauge as I don't need it (well not any time soon). Anyway, I'm selling both of them (relocator/guage) seperately unless the buyer wants both
Item: Oil filter 4AGE relocator kit
Item Condition: used
Reason for Selling: surplus
Price and Payment Conditions: $150 firm
Pictures:
Extra Info: The relocator kit is complete with 5 (3x 90 degree, 2x straight) Speedflow fittings, relocator and oil filter block. There is one spare Speedflow fitting but is not pictured hence 5 fittings and will also include a new oil filter used only as a test mule for fitting. The braided lines shown in the pic were replaced with new lines that are slightly longer. Item was used for 20 seconds if that but was removed as I forgot to tighten the relocator block properly causing a small leak.
Contact Details: via pm
Item: Omori dual gauge - reads both oil Pressure/Temperature at the push of a button
Price and Payment Conditions: $180 firm
Pictures:
Extra Info: Complete Omori dual gauge kit. It comes with the blue anodized sandwhich plate with numerous outlets for temperature and pressure probes. Comes with 2 thread adapters to suit 4AGE (3/4 UNF-16) and the other to suit the Pitch versions, both wiring harnesses, temp/pressure probes and 60mm gauge. Almost certain that you could even run a 1JZ/2JZ filter for more filtration if you wanted to. Gauge is electronic and not mechanical so only needs 3 wires (earth/power/illumination) wired up and is alot nearter than conventional mechanical-style gauges.
Buy both and I'll do it for $300 posted, if you are not interested in the item(s) please don't spam my thread.
Contact Details:
