you need a 4agze loom for a 4agze.
you need a 4agze ecu for a 4agze.
the N/A one will not work.........at all.
you can use the bigport extractors if you have a bigport GZE.
Ive tried searching around tech articles and google but cant find if eg. a 4AGE Bigport loom will suit a 4AGZE just curious what loom I need to run the 4AGZE and ECU.
Also if anyone knows how much it cost to get someone to custom make a loom and wire it up.
And one last thing can I use my 4age bigport extractors on a 4AGZE.
Thanks Ray
83' KE70 4AGE'D
84' AE71 4AG Twin 45 DCOE webers
Ok cheers mate so im guessing you just extend the loom somehow to suit RWD
83' KE70 4AGE'D
You extend the loom by cutting each and every wire and splicing in a piece of a length wire.
and if you're going to go to that much effort, you might as well just wire in an aftermarket ECU. 1 solder joint per wire as opposed to 2 for lengthening.
Yea I'm going through the process as we speak, using a AW11 bigport 4AGZE we've had to pretty much extend the whole loom. It sounds alot easier then it actually is, budget at least 15minutes per wire.. A day flies by pretty damn quick soldering in longer wires
Your bigport exhaust manifold should bolt right up though!![]()
Ok sweet thanks for all the help still weighing the pros and cons because the motor is for my AE71 which I use for daily driving also there is my budget aswell.
83' KE70 4AGE'D
Yea its a nice engine when its in.. But like everyone says, budget a good 4-5k for an engine conversion.
My engine only cost $1600ish and I did all the work at home with my dad, still a good 2.5-3k to get the job done.
wow wasen't expecting it to be so much thanks for that input mate ill just stick with recoditioning my 4AGE I have already much cheaper option.
83' KE70 4AGE'D
Exhaust ports are the same between bigport and smallport, so all 16V 4AGE exhaust manifolds are interchangable (20V has the same ports and most bolts, but just the outer two bolts are positioned slightly differently).
Also if you already have a 4AGE running then changing to ZE isn't that bad. Yes you need loom and ECU and intercooler work, but the fuel system is already in place and so on. I'd guess the above prices are based on 4AC - 4AGZE.
Yeah sorry forgot to add that my AE71 is still running the 4AC got the 4AGE in the backyard.
also thanks for the info on whether extractors are interchangeable.
83' KE70 4AGE'D
