During my search for an optical trigger I decided to get some other trigger devices. Hyundai have 3 wire Hall effect sensors
in most of thier cars so it wasn't difficult to find them and they were pretty cheap, about $10 from memory. Got back home
and wired it up, BINGO!!!! Full square wave signal!! Very stable and responsive. For anyone that is trying to do the same thing
here is a wiring diagram to get the signal out.
So that is the wiring diagram if you were to do a benchtop test to make sure that the sensor is functioning.
The ECU should have internal circuitry to reflect the voltage divider. The haltech manual just shows the sensor directly plugging into
the ECU so I would assume that it does not need to have the divider put in place. The sensor works by having a voltage reference from the input voltage
and when a ferrous material enters the field it develops a voltage at a 90 degree phase difference and an internal switch turns it off.
So basically the unit runs at a constant voltage (Ref Voltage) and then goes low when a tooth passes. Although using something like a piece of
ferrous metal will trigger the device it requires a very tiny air gap, almost 1mm. So by placing a magnet on the metal you can increase the gap to 5mm
and still have a very reliable, strong signal. For the best results just use a magnet as a tooth and you can get a distance of around 1.5cm, I was using
a hard drive magnet in that test so depending on magnet strength is how big the air gap has to be. To be safe an air gap of 5mm would be ideal.
Now I can start to make the trigger wheel!
