Hello!
as title says i've got a mostly complete s13 that i'm now pating out.
light purpley colour (will get pics soon) sr20de NON TURBO manual. got a canon with what look sabout a 2 to 2.5inch cat back exhaust. the car was slId backwards into a tree bucklIng the rear quarter panels and slIghtly bending the rail where to bumper mounts to it. would make a perfect track car shell.
SR20DE complete motor $800: comes with wiring loom ecu all accessories needed to run less clutch and flywheel. engine is in extremely good condition and runs very smooth and quiet. still running in the car for those who wish to inspect any mechanical tests welcome. i've had a bit of interest in some of the manual gear but not the gearbox on nissan silvia forums. if someone wants a complete conversion for a ke/ae i can work out a price aswell
MANUAL conversion $1000 manual conversion will come complete with every nut bolt clip that you'll need to convert your automatic car to manual. that means gearbox, gbox crossmember, tailshaft, clutch, flywheel, slave cylIder, clutch master cylIner, pedal box etc anyting related to car being manual you can have as part of the conversion
FRONT SUSPENSION complete sr20de brakes struts lca's castor rod 250 for both sides
BRAND NEW KYB EXCEL G replacement front struts. 150 the pair. BRAND NEW OMG!
thats the main stuff. still have radiator, engine xmember rear cradle diff and front suspension. not too sure what this stuff is worth atm but i'll work that out and post it up.
NOTE: DRIVERS SIDE FROTN GUARD, HEADLIGHTS, DOOR CARDS AND DRIVERS SIDE PARKER LAMP ARE GONE. everyting else is still there up for grabs
ALL PARTS LOCATED AT MONTROSE VIC
CONTACT ME VIA PM OR SMS 0438679977
will update ad with some pics and more prices later.
Thanks, Calvin
