Results 1 to 5 of 5
Thread: 4k twincam ke70
Threaded View
    Junior Member filfrederick's Avatar
    Jan 2010
    Phil
    Taringa
    Default 4k twincam ke70 the ultimate k
    OK,
    I have always had an obsession with the trd 3kr engine from back in the day, realised I was never going to get a real one so I decided to build my own.
    I don’t recommend this conversion to anyone I did it just to be see if it could be done. It took a lot of time and if I was not a fitter/turner a lot of money.
    Hope you find it as cool as I do.
    - Phil Matthews-Frederick.
    To save a lot of questions here are the specs.
    Head
    4AGE small port head, head stud holes elongated to suit 4k block
    Head face machined 2mm
    Front face milled to clear 4k waterpump
    Valve train
    Stock valves
    trd springs
    stock cams for now (294deg 8mm lift on the way.)
    belt drive system using 4ac pulleys
    38mm camshaft extensions
    Oil fed support block with needle roller bearings for camshaft extensions
    Crank pulley mounted on the front of the standard v-belt pulley
    Block
    Sonic tested
    Bores repositioned and overbored by 6mm
    Decked by 3.8mm
    Lifter bores, head oil drains and feeds blocked
    Mechanical fuel pump removed
    Crank
    Side counterweights removed
    Knife edged
    Balanced
    Shot peened
    2kg lighter than stock
    Flywheel lightened by 4kg
    Pistons
    Late 4age smallport cast pistons
    Balanced
    Conrods
    4age smallport rods
    Balanced
    Shot peened
    Oil system
    4k internal oil pump shimmed to 60psi oil pressure
    Hose feeds to head, cam extension bearings and oil pressure sensor
    All original head oil drains blocked
    External head oil drains
    4k camshaft remains to drive oil pump
    Sump
    Increased capacity by 1L
    Built in air/oil separator for crankcase breather
    Fitting welded on for oil drains
    Cooling system
    3 core alloy radiator
    Remote thermostat
    Heater ports blocked
    Ignition system
    4k electronic distributor modified to suit 4age head
    Ca18 sparkplug leads
    Inlet
    Quad Mikuni 40mm CV carbs
    70mm trumpets
    Exhaust
    Hi rise tuned length headers
    2” straight under-diff exhaust, huabusa muffler
    Externals
    3k-r look cam cover
    Electric fuel pump
  1. 4K TWINCAM ke70
    By filfrederick in forum Cars for Sale (Toyota Only)
    Last Post: 11th November 2012, 05:32 PM
  2. ke70 4k engine
    By 709OOD in forum Car Parts For Sale
    Last Post: 16th March 2011, 08:02 AM
  3. Replies: 1
    Last Post: 26th March 2010, 06:31 PM
  4. 4k ke70 exhaust
    By Ke70alex in forum Technical - Questions
    Last Post: 28th November 2009, 11:02 PM
  5. ke70 4age twincam
    By offtap87 in forum Car Parts For Sale
    Last Post: 29th June 2008, 04:32 PM
