Results 1 to 9 of 9
Thread: No low beam
    May 2010
    Glen waverly
    Default No low beam
    Hey guys, my headlights have been going on and off for some time now, I replaced my switch after reading up about it but it didn't fix it.
    The wiring to the switch has been tampered with, the dimmer wires bridged and the red wire cut and connected to another red wire.
    I've separated the dimmer wires and the dimmer now works, tried joining the red wire to the original red wire and no combination of the two are working. When I connect the red wire to the original red wore the high beam blue light comes on while there's still no lights on.
    Sooo yeah please help guys, switch is brand new
    Veteran Skylar's Avatar
    Ken
    Earth in the driver's side kick panel. White/black wire screwing into body. Make sure it's tight. If it is tight, undo it, clean it and do it up tight.
    May 2010
    Glen waverly
    Checked all around that area, can't seem to find said wire
    Senior Member DR86FT's Avatar
    Kaan
    Emerald
    sometimes the headlight switch has dry solder joints in it. thats how i fixed mine just be careful pulling it apart
    Stern but now fucked off...
    May 2005
    Nick
    Checked that the lights are actually working?
    I lost both low beams once on a KE70.
    Stick 12v to them and check that the low beams are working first, then work from there...
    May 2010
    Glen waverly
    Brand new bulbs, first thing I checked
    Veteran blair's Avatar
    Blair
    SEQ
    Have they ever worked?
    If not, then maybe your wiring is just actually wrong...
    May 2010
    Glen waverly
    They worked fine, then the left side dimmed down, then nothing at all (sometimes they would come on and off randomly)
    Blair
    SEQ
  1. Replies: 0
    Last Post: 22nd December 2011, 04:45 AM
  2. LOW BEAM PROBLEMS
    By BARWICK in forum Technical - Questions
    Last Post: 14th September 2011, 01:47 AM
  3. injectors for 3sge beam,s motors
    By Celica RA45 in forum Car Parts For Sale
    Last Post: 11th August 2010, 02:09 PM
  4. AE101 '92 Toyota Levin - LOW LOW kms - Clean - 5sp - VANCOUVER
    By lchazl in forum Cars for Sale (Toyota Only)
    Last Post: 30th July 2009, 08:23 AM
  5. Disconnect high beam / high beam switch
    By monkeymajik in forum Technical - Questions
    Last Post: 28th August 2007, 11:03 AM
