up for sale is my 1983 trueno coupe, has a little bit of work done.
the car really does go hard for what it is, handles the corners like anything and has even proven to take down evo 10's at queensland raceway.
really needs to be driven to be appreciated!!
mods are as follows-
engine:
bigport 16v (109,XXX kms)
hks 256 cams
rsr extractorts
HKS hi power cat back zuast
trd leads
trd iridium plugs
k&n filter
freedom ecu
oil catch can
aluminum radiator (out of service )
tuned for 110.5 HP atw's
front:
gab strut brace
GAB fully adjustable 8kg coilovers
trd sway bar
rose jointed lca's
ncra's
camber tops
prothane bush's
new pads
seam welded
rear:
GAB height + damper adjst shocks
GAB 6kg springs w/adjustable platform
trd sway bar
rose joint panhard rod w/2nd mount so its horizontal
welded rear strut brace
rear body brace
traction rods n brackets
seam welded
interior:
fully stripped
uncracked dash
nardi deep corn wheel
omari oil temp gauge
water gauge
sound deadening removed through out
rear seats removed
trd gear knob
seam welded
wheels/tyres
front; 15x8.5 -20 ssr formula mesh / 195/50/15 cheapys
rear: 15x8.5 -20 ssr formula mesh / 195/50/15 potenza reo1
also comes with full set of MA61's, trd copy side skirts, spare exhaust, radiator, adj cam gears and planty other bits n bobs.
Price:$12,500 neg
car is located in brisbane. I can be contacted by PM or email:jdell88@gmail.com or mobile: 0406930185 ( txt only)
