Results 1 to 7 of 7
Thread: 20v 4-age Silvertop into AE71
    Mar 2011
    Gabe
    Qld
    Nerang
    Default 20v 4-age Silvertop into AE71
    Hey guys,
    Im currently gathering parts for my 4-age 20v conversion into my ae71, the guy i bought it off have it converted to wasted spark system with coil packs from a hyundai sonata. He also gave me a distributor from the same car but it is broken, do i need a distributor to run a wasted spark?
    Cheers Gabe
    Moderator Sam-Q's Avatar
    Endeavour Hills
    you can't run a dizzy at all unless your one of those knob heads who chops holes in firewalls
    Senior Member Stain's Avatar
    Derek
    Far North
    or be tricky and relocate it to the front on the exhaust cam gear.
    Mar 2011
    Dave
    SE suburbs
    what ECU is going to run the motor? factory (use a re-located dizzy), or aftermarket (ditch the dizzy and run coil packs).
    Isn't the 20v dizzy essentially the equiv of a gze CAS, but you remove the cap / leads.
    Has anyone successfully set this up with a stock ecu and 1zz coil packs or is it not possible?
    Member geoff's Avatar
    Geoff
    Glen Waverley
    yes, there's a write up on samq's site
    (under ignition system)
    Veteran Skylar's Avatar
    Ken
    So dodge but whatever it works.
    The trick to getting the 4 coil/single ignition output is to make sure that your new coils' dwell time is same or a little less than the stock 20v coil.
  1. [PERTH] 20v Silvertop with ECU and loom, other 20v things for sale.
    By quadeyquade in forum Car Parts For Sale
    Last Post: 12th August 2012, 10:00 PM
  2. 20v 4-age silvertop dizzy and flywheel bolts
    By Gabe in forum Cars or Parts Wanted
    Last Post: 26th October 2011, 11:16 AM
  3. Replies: 4
    Last Post: 2nd September 2011, 10:32 PM
  4. Parting out: Silvertop 20V AE71 Spirit project - Pics added
    By beerhead in forum Car Parts For Sale
    Last Post: 31st July 2007, 03:50 AM
  5. silvertop 20v or blacktop 20v
    By Cj_sullivan in forum General Topics (No Technical Questions)
    Last Post: 6th September 2006, 12:42 PM
